Author Topic: VR6 Oil Pressure Problem?  (Read 2248 times)
Offline Cupra Turbo
« on: 07 January 2004, 23:38 »
Quote
Volkswagen Golf 1992-1998: Did you know an early Golf VR6 can suddenly lose oil pressure at around 100,000 miles, wrecking the engine?
that true?
http://www.golfgtiforum.co.uk/gallery/thumbnails.php?album=38
Modified Golf GTI, 130Bhp(est), All Smoked Plus Quad Headl
golfvr6
Re:VR6 Oil Pressure Problem?
« Reply #1 on: 08 January 2004, 23:53 »
Thats off parkers and thats bollox.
The only way that will happen is if the oil pump fails, that will happen if you don't change the oil regularly, as the pick up pipe will get clogged up with sh!t.
That could happen on any golfs as they use similar lubrication systems.
turbo
« Reply #2 on: 10 January 2004, 05:34 »
no thats wrong! like he's said!
to get  a sudden drop of pressure it must be fcuked in the first place!
it should never wear if theres oil lubricating it!!!
good oil that is! api sj, sf, /cf......... ACEA A3/B3
i recomend valvoline maxlife!!!!
very very very good oil!!!!!!
