Author Topic: Heater Fan slooooooooow!  (Read 807 times)
Offline skyman84
« on: 13 October 2006, 15:59 »
Hi folks,
Another question you guys might be able to help me on, the speed of the heater fans inside the car are really slow, even at full belt, they get up to temp well enuf, it's just with winter coming i don't wanna have to freeze my coco's off on the way to work because the warm air wont get to my face!
Any ideas what might be calsing this??
S
Offline Uruk Hai
Re: Heater Fan slooooooooow!
« Reply #1 on: 14 October 2006, 11:11 »
It mite just be a case of the motor being worn out, I put a new motor in mine.
Judderi
« Reply #2 on: 16 October 2006, 08:12 »
If your motor is actually turning id say its most probably the speed switch that needs replacing. Apparently the resistor in them fails leaving you with only 1 speed.
Offline Gambit
« Reply #3 on: 16 October 2006, 09:34 »
and the reason the resistor fails is because water gets into the motor and stiffens the movement therefore slowing the motor down. take the motor out and douse it in WD40 and it will free it up
if it still works on 3 settings then there is no need for a new resistor
Judderi
« Reply #4 on: 16 October 2006, 09:50 »
Every days a school day!
