Author Topic: rough idle  (Read 3139 times)
Offline keithcdb
rough idle
« on: 22 May 2003, 23:36 »
I own a mk3 golf gti 2.0 16v (93)
It starts ok and revs well, put the foot down and it really shifts !
but at idle it runs really ruff! it has a k&n filter fitted (not by me) not sure if it is original?
Any help gratefully received
Cheers keith      ???
« Last Edit: 01 January 1970, 01:00 by 1055631600 »
Offline trebor.vr6.
Re: rough idle
« Reply #1 on: 05 June 2003, 01:22 »
What do you mean by ruff. How many revs at idle.? Is there any shake or juddering
Offline keithcdb
Re: rough idle
« Reply #2 on: 06 June 2003, 23:06 »
it revs around 800rpm but there is a bit of shuddering going on if i am sitting at traffic lights and if i give the throttle a quick blip it drops right down to almost stalling !!
any ideas
Offline trebor.vr6.
Re: rough idle
« Reply #3 on: 07 June 2003, 22:52 »
The idle speed sounds spot on. ?I think your engine is ABF with a multi-point ?injection system. Maybe one of the injecter is not opening and closing at the right time. Try a couple of bottles of injector cleaner when you next fill up the tank. It sound like your engine needs a clean how about changing the oil while your at it. I would suggest a minium of  every 8 thousand miles  possibly less.......!
« Last Edit: 01 January 1970, 01:00 by -1 »
Offline Mikester
  • Civic Type R
Re: rough idle
« Reply #4 on: 02 December 2009, 19:47 »
Clean the throttle body.
lol :)
Offline Deano2711
  • 1992 VR6
Re: rough idle
« Reply #5 on: 02 December 2009, 19:55 »
+1  Clean the throttle body. My 8v had a similar problem until I cleaned the throttle body Monday night and now it's ok again. It's a fairly straight forward job.     Cheers     Deano
Offline javalin
Re: rough idle
« Reply #6 on: 02 December 2009, 20:03 »
sounds like its running rich - test & change the coolant temp sensor and/or the engine temp sensor if fitted.
« Last Edit: 03 December 2009, 08:38 by javalin »
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline justalex81
Re: rough idle
« Reply #7 on: 02 December 2009, 20:52 »
check the vac pipe from the inlet manifold to the ecu it senses the inlet air pressure. if it's knackered then the car will idle like a bag of sh!t
VW BUSH
Re: rough idle
« Reply #8 on: 02 December 2009, 20:57 »
You need Vag Com/Fault computer + Carb cleaner for Mk3's
Then when that fails come on ths forum for abuse help  :grin:
Offline t-tim44
Re: rough idle
« Reply #9 on: 17 December 2009, 12:14 »
mine did this as well. its was the MAF sensor. Mine was the hitachi type. Take it out, put boiling water into a bowl, give the maf a quick rinse in it, leave it a few secs and dry it off with an air line. That fixed it! Clean the TB too but as this is the usual problem.
« Last Edit: 17 December 2009, 12:17 by t-tim44 »
