Golf mk2
Water Temp
Topic: Water Temp (Read 3735 times)
Haydn
Water Temp
07 January 2004, 20:46 »
I have a jetta GTI 8v. The needle never gets above the white section on the temp gauge unless u leave it ticking over for about 20 mins. As soon as u start driving it drops back down to the white section. The heaters arnt hot just warm. The fan works so i am assuming the thermostats gone and is stuck open. Can anyone back me up on this?
JETTA GTI. Lots of fun with room for the shopping...
Blue MK2
Guest
Re:Water Temp
07 January 2004, 20:52 »
and your fan never comes on?
Same problem over here mate :'(
Veedubgt18v
Guest
Re:Water Temp
07 January 2004, 21:46 »
this happened on my driver, and that was a lazy thermostat and a blocked water rail,wouldnt come of choke either, but that was a gaybar pierburg
dubslug
Re:Water Temp
07 January 2004, 22:10 »
veebub dont supose u changed the pieburg for a weber and still have it laying abt some where??
1992 pearl grey 8v
Veedubgt18v
Guest
Re:Water Temp
07 January 2004, 22:14 »
nah the car was f**ked so i sold it about 2 months ago sorry! worth getting the weber tho!
dubslug
Re:Water Temp
07 January 2004, 22:25 »
would love to if i can find one cheap enough, cant afford full price otherwise id have a gti instead :-[ :'(v lol
1992 pearl grey 8v
Veedubgt18v
Guest
Re:Water Temp
Reply #6 on:
07 January 2004, 22:26 »
if you have a driver put an 8v cam in it, makes a bit of a difference!
dubslug
Re:Water Temp
Reply #7 on:
07 January 2004, 22:32 »
so wots the deal with cams and carbs??
im fairly new when it comes to engine work etc etc
1992 pearl grey 8v
Veedubgt18v
Guest
Re:Water Temp
Reply #8 on:
07 January 2004, 22:41 »
basically the more air and fuel in the stronger the burn so more power, also if the exhaust gases etc have a smooth path in and out then more fuel and air can get in/out quicker. try looking at engines on
www.howstuffworks.com
dubslug
Re:Water Temp
Reply #9 on:
07 January 2004, 22:45 »
cheers will have a look when im more awake, so will an 8v gti cam fit in my 1.6 89g plated golf??
need any other mods to make it fit??
1992 pearl grey 8v
Golf mk2
Water Temp
