Author Topic: brake trouble  (Read 1414 times)
Offline gtitdi
brake trouble
« on: 10 October 2006, 22:01 »
I've just noticed while driving with the window down that my Mk3 has an intermittent high pitched sqeak. Any ideas of what it could be?
« Last Edit: 22 October 2006, 13:09 by stehornsey »
Offline neil_1821
Re: High pitched squeak
« Reply #1 on: 11 October 2006, 09:41 »
Is it while your driving, stopped or constantly. It could be a fan belt looseor another belt loose for that matter. I know that my fan belt is slightly loose but i only get a squeak when i start it up.
« Reply #2 on: 11 October 2006, 09:47 »
I have the same, its my front brakes.  It only happens at slow speeds, and lifting the handbrake doesn't stop it, but touching the brake pedal makes it stop :)
Offline gtitdi
« Reply #3 on: 11 October 2006, 14:46 »
Its while im driving - I was doing under 30mph when I noticed it - so its probably the brakes like rubjonny. Is there anything that can be done or is it just one of those things?
« Reply #4 on: 11 October 2006, 16:49 »
you could try giving the front brakes a good service, new pads, clean up and copper grease the moving parts :)
Offline gtitdi
« Reply #5 on: 11 October 2006, 18:26 »
thanks - will have a look at the weekend - if it ever stops raining!
Offline gtitdi
« Reply #6 on: 21 October 2006, 12:50 »
just had it in the garage this morning so I got them to check the brakes out, they cleaned them up and regreased etc. n said that the squeak had gone- now its back! can anyone advise what i can do to get rid of it? also, im after a set of decent pads for general use - the ones on are tesco value! can anyone advise? thanks
also - after a 30min ish drive without hard braking the front wheels are hot to the touch so that i cant leave my hand on for long... is this normal?
« Last Edit: 21 October 2006, 12:56 by stehornsey »
Offline gtitdi
« Reply #7 on: 22 October 2006, 13:08 »
anyone?
Offline boneybradley
  • Back in a Mk3...
Re: brake trouble
« Reply #8 on: 22 October 2006, 18:47 »
Sound's like you could have a sticky caliper if they are getting that warm under normal braking....could be worth taking it to your local mot station and asking them to pressure test them on the rolling road thingy, this will tell you if one brake is sticking... regarding pad's i have all way's bought lockheed, as i don't race aroung too much and they give good feel compared to some other's
