Author Topic: GOLF GTI T HELP  (Read 1589 times)
Offline Adam-GTI-1.8T
GOLF GTI T HELP
« on: 10 October 2006, 14:10 »
Hi everyone im new here and ive just bought a golf gti turbo last week its done 60,000 and due a service is there anything i should get replaced like the cambelt?
There is also a ratteling noise at about 2000rpm could be the exhaust but not sure, has anyone else had this problem?
Any help would be great.
Thanks. :smiley:
Offline Rain
  • forum irregular
Re: GOLF GTI T HELP
« Reply #1 on: 10 October 2006, 14:18 »
id check the oil level first then have a listen for where its coming from could be anything.
Re: GOLF GTI T HELP
« Reply #2 on: 10 October 2006, 14:37 »
Ive had a look at the oil and that looks fine.
anybody else had the same problem?
Offline Flipmode
Re: GOLF GTI T HELP
« Reply #3 on: 10 October 2006, 18:35 »
stick your head under the exhaust and give it shake to see if theres excessive movement, could be loose bracket, careful not to get any muck in your eyes!! make sure your spare tyre is housed correctly and none of the tools are loose. If its more of a deep clunk it could be your rear suspension bushes which could be worn by 60k. also cambelt should be changed at around 60k so get that done, if it goes it can cause massive damage to other components. hope this helps a bit
Offline Stu-1.8T
  • Quit your Jibba Jabba
Re: GOLF GTI T HELP
« Reply #4 on: 10 October 2006, 22:20 »
Some VW dealers say 1st change of cambelt due at 120k. got mine done at 70k to be safe. While they are doing the cambelt get the waterpump changed aswell.
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: GOLF GTI T HELP
« Reply #5 on: 10 October 2006, 22:56 »
Also get the pulleys/tensioners changed while they're there, too!
ps My dealer quoted cambelt @ 60k!!??
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
