Author Topic: Not Again  (Read 2502 times)
Offline Golfgal
Not Again
« on: 07 January 2004, 11:43 »
My mk2 is being bad again. It keeps judderin - when I put my foot down there is no power and when idle it nearly cuts out. Then all of a sudden it will b fine.
Hasn't done it for ages tho. We replaced fuel pump and filter recently. Spark plugs etc were changed bout 10000 (woah done that much already) ago.
Any ideas would be helpful  :)
V5 Beetle owner. I'm just here for the misfire threads....
Offline richandhazel
Re:Not Again
« Reply #1 on: 07 January 2004, 11:46 »
Could be damp causing it to 'miss'. What are your HT leads and dizzy cap like?
Have a look under the bonnet in the dark with the engine running........is there lots of arcing and flashing?
Offline Golfgal
Re:Not Again
« Reply #2 on: 07 January 2004, 11:56 »
ht leads and dizzy cap changed same time as sparks to try and stop the problem. No arcing and flashing as I know but will check tonight. If I get home  ::)
When I try and take her to garage she's fine whilst in garage but as soon as I get her she starts playin up  ???
Thanx for help
mrwotto
Re:Not Again
« Reply #3 on: 07 January 2004, 21:39 »
dodgy coil maye golfgal????
Offline Helios_Blue_Valver
Re:Not Again
« Reply #4 on: 07 January 2004, 23:44 »
I agree with the coil. They tend to break down when they get warm. What about the Hall Effect sensor in the dizzie? What year and engine is your car?
Offline Golfgal
Re:Not Again
« Reply #5 on: 08 January 2004, 12:25 »
'90 H reg 8v
It only does it in mornings and its wen its at low revs. If I keep it bove 1.5 then its k and wen cars warm its ok. Don't wanna drive thru it incase by pushin it it does more harm than good.
Offline Fraiser
Re:Not Again
« Reply #6 on: 09 January 2004, 11:40 »
same thing was starting to happenon my 16 valver
got rid of it in the end.
Offline Golfgal
Re:Not Again
« Reply #7 on: 09 January 2004, 11:51 »
thanx lol
gonna get a vr6 put in that'll teach her!!
Offline JMallows
Re:Not Again
« Reply #8 on: 01 February 2004, 11:51 »
Sounds like carb icing
edit: apprantly not, as you dont have a carb'd car!
« Last Edit: 07 May 2012, 21:34 by JMallows »
A clever person solves a problem. A wise person avoids it.
