Author Topic: MFA Secret  (Read 7796 times)
Offline JezGTI
MFA Secret
« on: 07 October 2006, 11:55 »
Hi all, long time no..ahem...well nothing.
I would have put this with the Sticky of similar subject but I think only moderators can reply to stickies?
Anyway, I seem to be having a problem with my MFA readouts. I've been into the secret menu screens to help diagnose the problem but the thing is that I don't know what the typical readings should be. Does anyone have these readouts?
Great to be back, thanks Jez
Offline JezGTI
Re: MFA Secret
« Reply #1 on: 10 October 2006, 20:26 »
Anyone??.......Please.
Offline ...joe
Re: MFA Secret
« Reply #2 on: 10 October 2006, 23:12 »
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline JezGTI
Re: MFA Secret
« Reply #3 on: 11 October 2006, 00:17 »
Not quite (but thanks anyway), what i'd like to know is what should the actual readouts display, in numbers? For example I get a reading of 450ish for the vacuum, is this normal?
Offline takethefifth
Re: MFA Secret
« Reply #4 on: 11 October 2006, 00:36 »
I had a go tonight and this is what i got for an '88 PB GTI, 117k, K&N 57i, been running very well.
At Idle:
position 1:
Default: Engine code - 123
1: Land code - 3
2: Speedometer - 955
3: Upper rev limitter - 7418
4: Lower rev limitter - 1325
5: Decelaration fuel pressure - 220
6: Display test
MFA switch on position 2:
Default: Test programm of programmed bytes (checksum) - 2194
1: Intake Vacuum - 426
2: Digital rev counter - 900
3: Fuel usage (instantaneous) - 0.3
4: Signal from speedo sensor - 0
5: Oil temperature (like default)
6: Ambient temperature (like default)
At just under 3k rpm postion 1 readouts are the same. Switch 2 are;
1: Intake Vacuum - 292
2: Digital rev counter - 2880
3: Fuel usage (instantaneous) - 0.6
I couldn't put this info in the sticky but i hope Joe can. Hope it helps.  :smiley:
Offline Agreeable Slick
  • Unit
Re: MFA Secret
« Reply #5 on: 11 October 2006, 01:11 »
Re: MFA Secret
« Reply #6 on: 11 October 2006, 01:33 »
Smooooth!  :cool:
Offline Neaty
Re: MFA Secret
« Reply #7 on: 11 October 2006, 21:26 »
I cant believe I have had 4 Mark 2's and not known about this secret MFA thing. First thing I am gonna try when I get back in one  :smiley:
Offline monzablue16v
Re: MFA Secret
« Reply #8 on: 12 January 2007, 22:55 »
Do we have this for a 16v guys or could somebody check theres please? I am having loads of fuelling problems at the moment. cheers :)
