Author Topic: Mk V Gti Brake Bleeding sequence  (Read 2125 times)
Offline DeejayGti
« on: 04 October 2006, 20:05 »
Anyone know what is the correct brake bleeding sequence for New Mark 5 GTi. I have recently changed the brake fluid myself and used a one man bleeding kit but the brakes do not feel as responsive. Any help appreciated. Thanks.
Red 3 Door, Cruise, Sat Nav, Parrot, Black Monza 2 Alloys
Offline DeejayGti
Re: Mk V Gti Brake Bleeding sequence
« Reply #1 on: 07 October 2006, 00:19 »
I have been told its the same as the Mark 4. Can ayone advise?
Offline DeejayGti
« Reply #2 on: 07 October 2006, 15:23 »
INFO-
I did the bleed sequence from the Mark 4 today.
Rear right, rear left. front right and then front left.
Brakes feel much better................
 Dont know if correct but seems to work. Please advise f anyone knows what is correct.
Offline KINGS>
  • Watch out for the guns.....
« Reply #3 on: 07 October 2006, 16:29 »
the rule is start with the furthest away from the servo ie rear left then rear right front left the front right... unless the servo is on the oppo side then what you have done is right.
