Author Topic: mark 2 dashlights not very bright  (Read 3332 times)
Offline jasonpi
« on: 05 January 2004, 19:30 »
right, is there a fix for the above mentioned??
Veedubgt18v
Re:mark 2 dashlights not very bright
« Reply #1 on: 05 January 2004, 19:34 »
has the dimmer switch broken in your headlight switch? its that knurled little wheel thing!
Offline jasonpi
« Reply #2 on: 05 January 2004, 19:37 »
ive turned that up all the way, and my teeth are brighter than the console is ;D
Veedubgt18v
« Reply #3 on: 05 January 2004, 19:40 »
ok try another switch, or maybe your bulbs are week or a dodgy/loose connexion maybe?
Blue MK2
« Reply #4 on: 05 January 2004, 19:43 »
gotta be a faulty switch like Veedubgti8v said
Speedydub
« Reply #5 on: 05 January 2004, 20:14 »
I find that banging the top of the dash with your hand usually works........ ::)
Dinky
« Reply #6 on: 05 January 2004, 20:17 »
Just so us know,i just realised a cud turn the lights up just yesterday ::) only had the car about 5-6 months! ::) Plus i always thought it looked a bit dim(bit like me sel!) ::)
Dinky  :-*
kniterider
« Reply #7 on: 05 January 2004, 21:46 »
jason i think the bulb over the rev counter has blown matey!!!< ive just changed both in me new one today!!! bit of a twot to to but only took and hour bulbs were 1.50 for 2 ;D
kniterider
« Reply #8 on: 05 January 2004, 21:49 »
if when you have fitted new bulbs they are still (not very bright) then the 'dimmer' swith may be fauly but dont go buying a new switch!!! just loop it out!! its only a varialbe resistor!! loop it out then shell be bright!! , but i think its just the bulb above the rev counter blown!!!as theres light over the speedo and the clock lights up ok ;D
Offline jasonpi
« Reply #9 on: 05 January 2004, 23:02 »
advice taken as vw charge way to much for switches
just eager to get this car up to original standard i is a perfectionist
