Author Topic: cabrio hood not working  (Read 1111 times)
Offline bustersballs
« on: 26 September 2006, 20:03 »
mk3 cabrio,hood won't operate via the switch but works if power is fed direct to the pump. are there any relays fuses etc on the circuit to check, doesn't appear to be anything in the main fuse box.
Offline vwagain
Re: cabrio hood not working
« Reply #1 on: 26 September 2006, 23:19 »
Have you tried replacing the switch?
Stu
1996 2.0l 8v, black magic pearl paint<br />
« Reply #2 on: 27 September 2006, 07:28 »
to be honest, i haven't tried anything beyond putting 12 volts to the pump because i'm not even sure if there is a supply to the switch because i can't locate fuses/relays etc. will try and bridge the switch out to check that one. Cheers
