Author Topic: help with hand brake  (Read 732 times)
Offline gofasterstripe
« on: 23 September 2006, 12:43 »
ok here's the problem, my handbrake was not operating on the drivers side rear wheel. i decided to adjust the cable, when tightening the nut, (one where the spring is), the  bolt sheared off. What am i going to have to replace? is it the calipoers or the full servo ?
Offline takethefifth
Re: help with hand brake
« Reply #1 on: 24 September 2006, 22:39 »
Sounds like just the caliper unless you can get a replacement bolt. Not sure quite which bolt you mean, pic would be useful.
« Reply #2 on: 25 September 2006, 07:28 »
Sorry its the bolt that tightening up the tension on the spring that the handbrake cable attachs too on the caliper.
