Author Topic: Car not starting - Fuse box  (Read 2906 times)
Offline danhock
« on: 05 January 2004, 10:32 »
My golf won't start  :( :(
It turns over and i get a spark so it must be fuel related... Confirmed this by checking taking the fuel filter off and no fuel was coming from the tank..
Looks like the pump is near the offside rear wheel, is that correct... Its making no noise atall....
Thought i'd check the fuses and fuse 5 is burnt out completely and i cant get it out!!!
Is this for the fuel pump??
Dan
All opinions expressed in this mail are wholey owned by danhock and are not representative of golfgti.co.uk or it affliates.If you disagree with my comments please note that i do not give a f**k ?2005
Offline Helios_Blue_Valver
Re:Car not starting - Fuse box
« Reply #1 on: 05 January 2004, 11:07 »
Mine is a mk2 as opposed to a cabrio. Fuse 5 on mine is windscreen wipers. May be able to grab ahold of the fuse with a pair of needle nose pliers and wiggle it about and try pulling it out with a little bit of force. if it hasn't been out for a while it could have a touch of corrosion on it holding it in place or when it blew the added heat may have stuck it to the socket.  :)
Blue MK2
« Reply #2 on: 05 January 2004, 11:09 »
I dont know much about these fuel pump problems but have you tried changing the relays?
Offline danhock
« Reply #3 on: 05 January 2004, 11:09 »
I've a Hayes manual for the Mk2 (ive a mk2 engine) and that says windscreen wipers, but they work fine!!
Its actually burnt out big time and hald of it is stick in there.. cant get anything in to get it out....
« Reply #4 on: 05 January 2004, 11:15 »
I may stand corrected though mate. I wish my bently's manual showed the fuser panel for a cabrio. In mine for some reason under the 85-89 jetta fuse relay panel I have written fuel pump in pencil and a line going to fuse 5. When i look in the legend it says fuse 5 is the fuel pump.Jetta and cabby aren't the same fuse box are they?
Offline danhock
« Reply #5 on: 05 January 2004, 11:26 »
It all kinds of points towards that number 5 is the fuel pump....
Everything else works except the heater rear window but the light on the switch comes on sugesting its ok....
Doesnt anyone have a Mk1 manual??
Dan
Offline Mars Attacks
« Reply #6 on: 05 January 2004, 12:11 »
fuse 5 is definately the fuel pump as i have had the same problems recently and have gone through a lot of 15amp fuses. My pump is shafted or blocked so i'm replacing it.
Offline danhock
« Reply #7 on: 05 January 2004, 12:19 »
cheers wolfie....
It looks like its had a mini fire on that fuse!!
May have to get a new fuse box of move the fuse locations.
Offline danhock
« Reply #8 on: 06 January 2004, 09:24 »
Just to let you know, it was fuse 5!!!
Cars runs a treat now... Changed the spark plugs while i was trying to find the fault and its made a big difference!!
