Does it only happen at certain revs or is it when you go over bumps etc? Only mention this because a heat shield came loose on mine a couple of weeks ago which caused an alarming vibration noise at certain revs and it was coming from somewhere below the handbrake/gear lever. Should be easy to sort if it is.sorry to hijack but the last few times I've started mine up there is a slight knocking coming from the rear which kind of sounds like the exhast hitting something but then thats it - it only happens at startup. Serviced last month and they changed the fuel filter - could this be loose or something?thanks
