Author Topic: MFA query - Outside temp not working  (Read 1186 times)
Offline 16v
« on: 19 September 2006, 11:10 »
Hi,
My MFA has just developed a fault. The outside temp display has disappeared.
As you scroll through the settings, after "oil temp", it just jumps straight back to "time" and misses "outside temp" out.
Any ideas what could be causing it?
Coincidentally (maybe) I've just had a new Clifford Alarm fitted and it has only started doing it since then.
Judderi
Re: MFA query - Outside temp not working
« Reply #1 on: 19 September 2006, 11:12 »
Sounds like the wire to the sensor has been cut or broken.
« Reply #2 on: 19 September 2006, 13:22 »
you can find the sensor inside the passenger wing, clipped into a hole just behind the bumper.
Offline 16v
« Reply #3 on: 19 September 2006, 14:40 »
thanks
Will have a look.
 :smiley:
Offline gti jim
  • return of the vac...
« Reply #4 on: 19 September 2006, 19:57 »
shameless hi-jack  :grin:
do you have to remove the bumper to get at the sensor??   :huh:
Offline Bluefox
  • ...back again!
« Reply #5 on: 19 September 2006, 20:00 »
Shameless indeed!
I think all you have to do is take the wheelarch liner out don't you?
Bluefox
Current: '84 Golf C 1.9 TDi | '01 Polo GTI | '01 Audi A2 TDi | '83 MG Metro
Previous: '83 GX | '04 R32 | '93 VR6 | '86 GTi 8v | '88 Diesel | '92 G60 | '04 Skoda Superb TDi | '90 GTi 8v | Plus many more!
Project Thread - http://www.golfgtiforum.co.uk/index.php?topic=270683.0
« Reply #6 on: 20 September 2006, 08:11 »
Don't have to do either, you can just reach up from under the wing to get to it.  Its a bit more tricky if you have big bumpers though.
Removing the liner will make it easier :)
