Author Topic: FACTORY SPORT SUSPENSION FOR GTI / Mk.V  (Read 2237 times)
Offline Hotshot 5
« on: 19 September 2006, 06:41 »
As I understand 17" wheel on GTI does not come with "sport suspension" which is 10mm lowered than normal suspension. If you opt for the 18" wheel then, the "sport suspension" comes with it as std equipment.
If I would like to order the "sport suspension" kit which consists of 4 lowered springs from VW. Does anyone know the #part number for this "sport suspension" only?
I intend to use Koni FSD shocks & factory lowered suspension kit. It seems that the factory sport suspension gives a good compromise on sporty driving & comfort. Thought about Eibach lowered springs but I think there are harder & also lower (20-30mm) than the factory ones. Furthermore, Apparently they do not have a lowered kit specifically for GTI. What they have is just a kit for Mk.V but can be used on GTI.
Offline ReDBull
Re: FACTORY SPORT SUSPENSION FOR GTI / Mk.V
« Reply #1 on: 19 September 2006, 13:11 »
Didn't Fancy undoing all of VW's good work with the suspension so had morego's power grip wishbones fitted up front. They improve the grip with out making the car a pain in the bum to drive. You could also try some better Tye's?
03 210 Seat LCR. Badger5 V2.2TIP, Fordge 007p, Wellycooler, Quaife ATB LSD, Nuespeed ARB's, KW Clubsports, 330mm discs, 3" turbo back de cat and still on the standard map!
My project thread: http://www.golfgtiforum.co.uk/index.php?topic=241116.0
Offline lowdown
« Reply #2 on: 19 September 2006, 20:35 »
Sports suspension (lowers the car by 15mm on GTi and 20mm on R32) is standard on all GTi's/R32's irrespective of wheel option.
