Author Topic: grill question  (Read 7315 times)
R1D3R
grill question
« on: 03 January 2004, 19:22 »
just got my debadged grill. what i wanna no is how do i put the little bit of metal trim on the bottem if it has no slots for it?  :o
dont tell me i have to paint this part!
humm. help us out tah.
Offline jedi16v
Re:grill question
« Reply #1 on: 03 January 2004, 20:16 »
hello mate you could try bending the tabs on the metal and using glue or some other sticky substance
R1D3R
Re:grill question
« Reply #2 on: 03 January 2004, 20:20 »
no ive found out its basicly one built onto the grill. so the metal wont fit over it! shame its black like the rest of the grill and my car is white!
hum that was a good waste of ?45  :'(
Offline jedi16v
Re:grill question
« Reply #3 on: 03 January 2004, 20:25 »
knightmare mate . should be quite easy to spray though . because white is a flat colour you should be able to use spray cans to paint it . get some wet and dry paper (fairly fine) rub down the plastic this gives the paint somthing to stick to . spray some plastic primer on it first let it dry . again gently rub down the primer to get a 'keyed' surface and carfully spray the whit in layers letting each layer dry . quick tip don't get to close to the grill with the spray can as i have found out it can run quite bad  :)
R1D3R
Re:grill question
« Reply #4 on: 03 January 2004, 20:29 »
did u spray yours then?
hum ive done enough spraying on my car to last a life time! ive had enough, specialy with all this wind about. my garage aint big enough and light enough to spray and outside the weather is to sh!t.
i doubt he will take it back now aswell.  :(
Offline jedi16v
Re:grill question
« Reply #5 on: 03 January 2004, 20:34 »
i didnt spray the one on this car. i made up a new designed mesh grill to fit it using original grill and a bit of fibre glass . but the b*$$&rd thing didnt fit the clips were in the wrong fekkin place . spent hours making it aswell . was'nt best pleased i tell you. who ever you got it off should take it back if you have your reciept and any packaging . if it is all ok you are in your rights to have a full refund
R1D3R
Re:grill question
« Reply #6 on: 03 January 2004, 20:36 »
i got it off a guy called Sweedish on this forum!
Offline jedi16v
Re:grill question
« Reply #7 on: 03 January 2004, 20:37 »
has he been on since?
R1D3R
Re:grill question
« Reply #8 on: 03 January 2004, 20:39 »
dont think so,
hes floggin alot of FK stuff to us lot.
Offline jedi16v
Re:grill question
« Reply #9 on: 03 January 2004, 20:47 »
do you think hes genuine? or a bit dodge?
