Author Topic: ignition barrel  (Read 1172 times)
Offline snake16valve
ignition barrel
« on: 17 September 2006, 18:05 »
Hi again folks...
How easy or how hard is it to take out an old barrel and fit a new ignition barrel ?
Thanks for any help.
Re: ignition barrel
« Reply #1 on: 17 September 2006, 19:11 »
you have to drill a hole in the ign lock housing, the haynes has the measurements.
Re: ignition barrel
« Reply #2 on: 17 September 2006, 21:19 »
Cheers rj for the info.
Fix it tomorow...i hope.
Offline Gambit
Re: ignition barrel
« Reply #3 on: 18 September 2006, 12:02 »
are you not just changing the ignition switch??
Offline monzablue16v
Re: ignition barrel
« Reply #4 on: 18 September 2006, 12:05 »
Remember to put the key in and turn it to pull it out.
Re: ignition barrel
« Reply #5 on: 18 September 2006, 13:20 »
dont need to put the key in to remove the barrel, at least you dont on a 90 spec one :)
Re: ignition barrel
« Reply #6 on: 19 September 2006, 19:02 »
Got the barrel out and there was a small screw that was loose.
I just gave it a good tighten and put it all back together and now the ignition works fine.
