Author Topic: Gear box problem  (Read 2680 times)
Offline TOFF
Gear box problem
« on: 03 January 2004, 15:48 »
Having problems with the gearbox....won't go in reverse, 1st, 2nd or 5th. Could it be the gear linkage or will it need a new gear box?
Mkiii 16V
Offline richandhazel
Re:Gear box problem
« Reply #1 on: 03 January 2004, 16:13 »
If it was Mk1 or 2 I'd definately say check your linkage before condeming the box.........not so clued up on Mk3, are they cable operated? '6 or someone will be along soon to advise, I'm sure ;)
golfvr6
Re:Gear box problem
« Reply #2 on: 03 January 2004, 22:20 »
Probably the cable linkage. I take it goes in 3rd and 4th ok?
Offline TOFF
Re:Gear box problem
« Reply #3 on: 04 January 2004, 11:16 »
Yeah, it run fine in 3rd and 4th but it'll burn out the clutch if i drive it in this state..how easy is the linkage to fix?
Mkiii 16V
