Author Topic: Mk3 HandBrake Light always on dash?  (Read 1553 times)
Offline jonboy
« on: 13 September 2006, 22:36 »
Hi just got a mk3 golf , but handbrake warning light is always on!  Checked fluid ok.  removed lead to  fluid level sensor and lead to hand brake sensor but still stays on!!  any ideas please thanks
Offline monkeyalan
Re: Mk3 HandBrake Light always on dash?
« Reply #1 on: 13 September 2006, 22:43 »
do you have ABS? when both my front sensors packed in the handbrake light stuck on.
If you have ABS the light to the right of the steering wheel should light up when you start the car and go out after a few seconds.
Offline spankyVR6
  • better a seated piss than a standing sh!te
« Reply #2 on: 14 September 2006, 14:15 »
The cap on the brake fluid reservoir may have gone bad (connections, electrical plugs etc). Try giving it all a good clean. It may not be this but it's worth a try! :wink:
What model is it? I know the VR6 has a low level brake pad warning light (seperate to the handbrake light). Not sure but other models might have the handbrake light double up as this warning, so check your pads for wear! :wink:
« Last Edit: 14 September 2006, 14:19 by spankyVR6 »
