Author Topic: Accelerator pedal sits low  (Read 1932 times)
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
Re: Accelerator pedal sits low
« Reply #10 on: 26 February 2007, 15:05 »
as long as your carb opens all the way then no need to worry.  Its an asthetic problem ;)
If you want the pedal to be level you want a taller pedal stop, otherwise you risk stretching/snapping the cable whenever you floor it.
Ah ha, yeh had thought, he carb does open and clsoe perfectly well, youve seen my pedal, it doesnt grind anymore luckily  :grin:
Oh and ive lost that disgusting noise and impossibility to start for 30seconds, changed the rubber block/flange between carb and mani the old one had blown a hole right through solid rubber :shocked:
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
