sorry, i see what you mean now. no there's no easier way but to take the dashboard unit out. What you need to do is take out the air vent grill to the right of the board (take out the two screws behind it), the panel with the airbag light in it (it'l just lever out with a small screwdriver) and then the light switch unit, unplugging both of them, then remove the two screws you just uncovered. If you then look to the left of the dashboard theres a small plastic cover which will pull out to reveal another screw - take that out. The whole panel should then come out with a bit of twisting! This uncovers the actual dasboard unit - you'll see a screw at either side - take these out, the board will then swing forward (it's hinged) then take out the plug at the back and unclip the dashboard and it will come out.
The bulbs come out with a twist and a pull. I've got loads spare if you need any, I took them out to replace them with blue LEDs
