Golf mk1
car just seems to pause at 4500 rpm
Topic: car just seems to pause at 4500 rpm (Read 3263 times)
BobbyT
Housemusic aint for everybody,only the sexy people
05 September 2006, 14:58 »
hi all, well my car is off in to the garage tonight to get the gearbox sorted but i also have another problem and i have no idea what is causing it! when you put your foot down hard the car gets to about 4500rmp and then sounds like it is miss firing and it wont rev any further! i have changed the coil, dizzi cap and rotor arm! what the hell could it be, it runs fine at all other times just when you boot it.
Tucker
Here all the time
Re: car just seems to pause at 4500 rpm
06 September 2006, 21:58 »
hall sender in the dizzy?
http://i10.photobucket.com/albums/a109/sydney04/mk116vsmallpic.jpg
Sig too large, see forum guidelines - Admin.
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
07 September 2006, 15:31 »
sounds like the timing is out to me!
GemGTI
Here all the time
Gemma
11 September 2006, 13:21 »
Don't boot it?
Mine never seems to get anywhere near 4500rpm even when 'booting it' !? that normal? usually 3500 is tops for me
G
rubjonny
10k hero
11 September 2006, 13:29 »
defo is not normal, at 3500 you're not even at peak torque! Peak BHP is around 5400ish.
Theres a redline on your rev counter for a reason
Last Edit: 11 September 2006, 13:34 by rubjonny
GemGTI
Here all the time
Gemma
11 September 2006, 14:02 »
My engine sounds like I'm thrashing the guts out of it if I go past 3500! Didn't know you were supposed to use the red bit?!
rubjonny
10k hero
Reply #6 on:
11 September 2006, 14:24 »
You shouldn't go into the red zone, theres no power there anywhere. But just before it is fine! If you think 3500+ revs sounds bad dont bother buying a 16v, and stay well away from a honda
BobbyT
Reply #7 on:
11 September 2006, 15:39 »
well i have aksed the guy at dubstar to sort it out, he took it out and said it feel like the ignition so i guess the timing could be out! oh and jem you should be able to get yours to 5000 with out any problems mine used to! is yours a 1.8 or 1.6?
GemGTI
Here all the time
Gemma
Reply #8 on:
11 September 2006, 16:44 »
1.6 aaaagggghhh 5000 sounds scary! Maybe I just drive my car too carefully!
Daz...
Reply #9 on:
11 September 2006, 16:49 »
Where does the redline start? I thought it was about 6.25k
5.5 - 6k shouldn't be a problem for your engines!
08.03.10 - 3, maybe 4 weeks, and I want my golf back on the road!
Golf mk1
