Author Topic: HELP!!!  (Read 1113 times)
Offline trish
HELP!!!
« on: 03 September 2006, 13:13 »
:sad:
Hi to you all,
I have a golf 1.8 GTI year 2002,
I have had the car for two months and i love it.
But i have just encountered my first problem a light on the dashboard stays on, my manual says its the exhaust emissions????
can anyone help???
« Last Edit: 03 September 2006, 13:17 by trish »
Offline Desperado2
Re: HELP!!!
« Reply #1 on: 03 September 2006, 16:37 »
Which light? The amber one which looks like an engine which says 'Check'?
Is so that is gust a generic warning light which means the car has found a problem with it'self. My car brings up this light regularly. I just check out the code with a VAG-COM and then reset it as normally it's a faulty sensor.
Offline Angloital
Re: HELP!!!
« Reply #2 on: 09 September 2006, 09:45 »
I had a Mark 4 V5 and this light came on 5 times, twice it was coil packs and the engine ran really badly in "safe" mode and had to be recovered, twice it was just sensors but once it was because the engine fan fuse had blown!! If your engine is running ok which it sounds like it is then I would guess either a sensor (cost about £100 to get fixed) or if you are lucky the fuse (15p)
Hope this helps
The car in front is a Toyota............but only whilst I change down a gear!!
Offline GolfGL
Re: HELP!!!
« Reply #3 on: 09 September 2006, 21:42 »
Best thing is to get it diagnosed at a garage with vagcom as the mk4s have various problems most likely a lambda sensor, MAF or coolant sensor.
Audi TT 3.2 24v v6 2005 - The Sloth - Weekends
VW Golf 2.0 8v GTI 1996 - Lemonade II -Daily
MNR Vortx Yamaha R1 2009 - Track days
Sold Seat Leon Cupra R 225 -LM04 NDE "Lemonade"
