Author Topic: DIY Wheel Repair  (Read 2576 times)
Offline Tornado
DIY Wheel Repair
« on: 02 September 2006, 13:45 »
Hello
I have just acquired some alloys ( ebay unfortunately) and the wheels while generally ok have scratches round the edges.
I would like to repair these myself, has anyone done this before?
I thought I might start with a dremel then do some wet and dry then polish but any good tips would be useful.
Ta
Alan
Lower!
Offline Tornado
Re: DIY Wheel Repair
« Reply #1 on: 03 September 2006, 11:46 »
Hello again
 :sad:Has nobody tried this then or is it just a sh!t idea? :smiley:
Regards
Alan
Lower!
Offline Uruk Hai
« Reply #2 on: 03 September 2006, 19:52 »
I just finished sanding down 4 BBS RA's by hand and I'm never ever doing it again (I have no finger prints left  :undecided:), having said that I am very happy with the results and all I used was a few scotch pads some 240 grade sanding disc's and a small file for going around the edge of the rim to smooth out the rough bits and kerb scrapes. There were a few dents and for that I mixed up a tiny bit of filler and put as little as I could in the dent and then flatted it back with the rest of the wheel, there were a few bits of quite heavy corrosion so on those bits I used a dremel with a steel carbide wire brush and ground it back to the bare alloy. After rubbing the wheel down I etched primed it and this shows up any uneven bits or heavy sanding marks so I can go over those bits with 4 or 6 hundred wet and dry, when I've done this to all 4 wheels they'll be painted, thank god  :grin:
Judderi
« Reply #3 on: 05 September 2006, 09:15 »
Its certainly is allot of work!
Offline rowlers
  • I'm back - MK7 GTI
« Reply #4 on: 06 September 2006, 21:13 »
I too have just refurbed a set of ATS Cups, and will repeat what Uruk said, no finger prints left, absolutely knackering, and would deffo not do it again. Having said that I got a set of nice looking rims for £70, and am please with the results.
Take them to a specialist and pay the £40 per wheel!
Offline Uruk Hai
« Reply #5 on: 06 September 2006, 21:23 »
Amen to that dude  :grin:
Offline Len
« Reply #6 on: 07 September 2006, 15:03 »
I'm about half way through doing a set of Momo's. I started off using a metal file, then a good Isopon metal filler then good grit paper.
Just gotta get the paint matched.
www.sas.org.uk
www.the-ace.org.uk
