Author Topic: hot starting/running  (Read 785 times)
Offline kittie
« on: 02 September 2006, 11:26 »
I have a problem with my 8v when starting it hot. It starts/runs fine when cold, but if I run it up to temperature and then, say, pop into asda for 10 min, then start it up again, it'll start ok but then a few seconds later will die.
When it does this the revs climb up a little then plummet and its impossible to keep going or bump it. Once I restart it and drive away it's fine again. Never has any trouble starting or idling at any other time.
It's recently had a service - plugs/leads/rotor arm etc.
What could be the problem? It's starting to get on my wires!
Re: hot starting/running
« Reply #1 on: 04 September 2006, 14:07 »
what year is it :)
If its post 87, 1st thing I'd do is replace the ECU temp sender, only cheap from VW.
Offline kittie
« Reply #2 on: 02 May 2007, 12:11 »
Sorry to drag up an old post but I've finally gotten round to swapping the blue sender and it hasn't cured the problem - any other ideas?
 :grin:
« Reply #3 on: 02 May 2007, 12:27 »
check the wiring to the throttle switches and make sure the idle switch clicks when the throttle is closed.  Have a read of my digifant tuning guide as well :)
Offline kittie
« Reply #4 on: 02 May 2007, 18:17 »
hmmm I was having some fast idling problems too and my boyfriend found a broken wire around there, fixing that solved the idling problem.
I guess I'll have to pursuade him to look at the rest of the wiring as I'm pretty hopeless with anything electrical!
Will read the guide now, although I have glanced at it before and decided it was too complicated!   :laugh:
