Author Topic: door panels  (Read 3133 times)
Offline judderman
door panels
« on: 24 February 2003, 15:07 »
Hi all,
Should i be aware of anything before i start to tackle taking off my front door panel's  ???  are there clips behind or just screwed on  :-/ i need to change a speaker  :o
Cheers  ;)
« Last Edit: 01 January 1970, 01:00 by 1055631600 »
Offline Ows
  • Phat mk2 sitting low- dont sleep the mk3 is next!
Re: door panels
« Reply #1 on: 24 February 2003, 21:02 »
just clips, undo the door handle and sort out the fob bit for the lock then gentle easy the panel away, it might be quite stiff if its never been off b4
Gentle persuasion is the order of the day
Ows
Roll on hitting the limiter in a peachy vr6
Offline stoat
Re: door panels
« Reply #2 on: 25 February 2003, 16:49 »
There are four screws holdind the door card which are visible when you open the door, two behind the door handle (the one you use to close the door), the surround around the door handle and then the rest are just clips
MK3 GTI 8V
Offline judderman
Re: door panels
« Reply #3 on: 25 February 2003, 20:01 »
Cheer's for the info  ;)  but didn't need to take the panel's off  ;D  i had to change the speaker's and there was only one screw!!!
Sorted  8) ;D 8)
