Author Topic: front passenger wheel hub  (Read 1323 times)
Offline nadlad
  • Building Surveyor MRICS
« on: 01 September 2006, 12:37 »
i require a front passenger wheel hub, wheel carrier and brake callipers for a golf mk4 1.8t or a leon cupra 1.8t pls
any ideas or directions to point in wud be grateful
thanks
<<<Big Build Thread>>>
Offline Rhyso
Re: front passenger wheel hub
« Reply #1 on: 01 September 2006, 13:07 »
just the one??
have you already got 1.8T hubs on your car?? or are they for another car?
think they are about £40ish new from a dealer  :undecided:
Offline nadlad
« Reply #2 on: 04 September 2006, 17:26 »
well my car was in a knock and the guy who repaired it fixed a 1.8 t wheel hub, wheel carrier and brake callipers only found out when  i was chenging the discs that the 280mm standard disc wud not fit in the 288 discs that are on the drivers
so now looking for a front left wheel hub assemply, think i may aswell upgrade to  the 288 set up since there better especially with the revo.
if i leave it and knock someone down ill be a wee bit fcuked.
not that i notoced anything in ten thousand flawless miles!!!!
so if soem one could get hold of soem part numbers wud be appreciable.
Offline Rhyso
« Reply #3 on: 04 September 2006, 19:14 »
right haven't got the numbers to hand but may do by the end of the week.
having 312mm discs fitted  :wink: if you are getting the hub you might want to think about going to 312mm.  you just need the caliper carries and the discs and its a straight fit to the 1.8T hub
but am i right in thinking that your drivers wheel has a bigger sized disc than your left wheel???
Offline nadlad
« Reply #4 on: 05 September 2006, 08:19 »
at the mo i got a 288 set up off a 1.8t on the right and i got the bog standard 280 normal tdi set up on the left one way or another they need to be both the same so i was thinkign of just gettign the 1.8t setup on the left aswell as it will cost same money from breakers.
i just dont know where and what part to get am i right in thinking that all gti turbo  have the 288 wheel assembly, hub and caliper carriers that my front right side has?
pls help.
Offline Rhyso
« Reply #5 on: 05 September 2006, 08:46 »
yeah you are spot on with that assumption.
i think a new hub is about £40 from the stealers  :undecided: not sure on the carrier though though i'd imagine its pricey  :sad:
have you tried GSF?  :undecided:
can't believe the mechanic stuck a different assembly on your drivers side!! that's utter madness  :shocked:
