Author Topic: Urgent: New Engine Help needed  (Read 1345 times)
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
« on: 31 August 2006, 18:55 »
Well, my mate has jsut phoned me to say after all the work we have commited to my car, head skimmed, rubbed down new gasket on there and inlet and manifold.. new cambelt fan belt new sparks, new everything surrounding the head and making it running, and lo and behold its still kicking out white smoke like an absiolute b!tch.. the cosmetic is absolut perfect so i really dont want to let it go as i have spent a lot on restoring it to its standard look.
Now, i need an original 1.3 engne to go back into it, my mate said it could be anything the rings whatever, as its burning fuel on idle..
would a new carb be a good start to see if it fixes it? if its jsut the carb gone, but then the worry of the rings, pistons, the whole score down inside..
would a new engine forma breakers be an idea? i mean, you dont know whats wrong with that one then, do you..
..help  :cry:
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline T_J_G
Re: Urgent: New Engine Help needed
« Reply #1 on: 31 August 2006, 19:02 »
May be better off posting this in the garage section for better results. :cool:
I'd say a new engine maybe, and swap parts over until you find out what makes the smoke..
« Reply #2 on: 31 August 2006, 19:06 »
Cheers man ill put it there as well, i figured, main board, many people will see it heh heh. Well, i guess the carb is somewhere to start if its burning fuel and kicking smoke eh..
Quote
Offline Dizzie
  • Make friends with your fast
« Reply #3 on: 31 August 2006, 19:14 »
if you had the head off and it skimmed it would of made sense to pop the pistons out and replace the rings really if it was smoking a bit. if it's not the rings I would put it down to the valve stem seals.
Mk4 Golf 150PD
« Reply #4 on: 31 August 2006, 19:19 »
i didnt do the work, a mate of mate did it, all he did was the gaskets nothjing else, it wasnt smoking before due to how the gasket was so bad.. we could hardly run it!
Quote
Offline ...joe
« Reply #5 on: 31 August 2006, 19:28 »
white smoke is normally from head gasket problems. you/he did torque the head bolts down properly didn't you? i'd whip the head off again and see if you can spot the problem.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
« Reply #6 on: 31 August 2006, 19:40 »
yep, all present and correct, been told that oubviously if you open it up, check it, do soemthing and put it together again and then its the next thing down the line, youll be there for forever and a day and spending your bank account+1.. where you could drop a new engine in at home on the drive..
as i say, what do you guys say of a volks-only speciailist breaker for anew engine, its Volksmania in Old Sodbury, down bristol bath way by the way
Quote
« Reply #7 on: 01 September 2006, 13:38 »
found an engine, same one, never been skimmed or anyhting, had a aldy owner for th 5 years they have been servicing it and known the car and had nothing major on it, £100
and a webber carb, with everything but the manual choke cable, £45
sorted  :smiley:
Quote
Offline ChrisO GolfO
  • See thru it
« Reply #8 on: 01 September 2006, 14:22 »
had a aldy owner for th 5 years they have been servicing it and known the car and had nothing major on it sorted  :smiley:
You outta be careful of them aldi owners!
Who wanna get halfed up by a half wit
Who got a gang a problems
And dont give a half sh!t b!tch
« Reply #9 on: 01 September 2006, 17:49 »
 :grin:
i was in a rush, and was excited at the prospect haha  :laugh:
Quote
