Author Topic: Rear ABS sensor replacement (VR6)  (Read 1035 times)
Offline alger
« on: 30 August 2006, 22:28 »
Can any1 out there tell me how to replace? Is it a hard job?
cheers
Offline adyh
Re: Rear ABS sensor replacement (VR6)
« Reply #1 on: 31 August 2006, 09:54 »
Easy , as long as you can get the old one out , they become stuck due to grime and heat etc.
1) lift up you back seat , you should see two wires , one going towards each wheel .
2) unclip the cable to the failed sensor and push the grommit through to the outside of the car.
3) remove the wheel , jack car up properly , axle stands if you have them .
4) you should be able to trace the cable in its plastic holders down along the rear suspension arm to the rear of the brakes.
5) its just held on with an allen keyed bolt . and should move towards the centre of the car.
6) reverse procedure with the new part .
Offline alger
« Reply #2 on: 31 August 2006, 18:13 »
so you dont have to remove the disk then......?
Offline adyh
« Reply #3 on: 01 September 2006, 10:01 »
In theory no , but in the event i did . If only to give the old sensor some 'help' .
Offline alger
« Reply #4 on: 01 September 2006, 13:16 »
cheers mate. one other quick question, where is the best point to put the axle stands?
