Author Topic: Funny sounds...cambelt?!  (Read 1591 times)
Offline T_J_G
« on: 30 August 2006, 20:46 »
Hey there
When my car is still and running there's a clicking kind of noise coming from near the cambelt..
also when i acccelerate through the gear, it whines like a supercharger but bit louder...
Just hoping it's nothing major as i'm dong a 200 mile rund trip to e38 onm saturday/sunday.
If anyone can enlighten me?!
Tim
Offline AudiA8Quattro
Re: Funny sounds...cambelt?!
« Reply #1 on: 30 August 2006, 20:51 »
Take the cover off and have a look.
Offline Agreeable Slick
  • Unit
« Reply #2 on: 30 August 2006, 20:59 »
Any of the belts like alternator or PAS belt been changed recently? They could have been overtightened. Bit like mine  :laugh:
Offline keithyboy
« Reply #3 on: 31 August 2006, 09:09 »
An overtight timing belt makes a sort of whining noise which changes pitch as you rev the engine. Shouldn't tighten itself though, it would only be a problem if the belt has only just been changed. Could also be the tensioner. My old knackered one was making all sorts of peculiar noises.
Wrong wheels and mine's Calypso not snot but it's close enough
« Reply #4 on: 31 August 2006, 09:40 »
It might be the bearings in your tensioner, 1st thing I'd do is loosen the PAS & alternator belts a tough, see if the noise goes away.  If not, loosen the cam belt slightly, you should be able to twist it 90 degrees at the longest point if its an 8v, and a bit less if its a 16v!
I'd shove a new tensioner on there at the same time!
Offline barkstar
« Reply #5 on: 31 August 2006, 13:08 »
My cambelt tensioner screeched a fair bit, even though it's clearly pretty new. So I gave it a dose of WD40 on the off chance and it's quiet as a mouse now. I'll be fitting a new one soon just in case as the tension was too high so I guess the bearing in it will be bu**ered.
Barkstar  :nerd:
Offline T_J_G
« Reply #6 on: 01 September 2006, 22:37 »
Right loosened the bugger off, no longer does it make a uspercharged sound! waheyyy!
But the clicking/rollnig noise still happens. But it shall be booked in for a cam belt change/tensioner when i get back from e38.
Tim
Offline Mr Blue
« Reply #7 on: 02 September 2006, 00:52 »
happend on my mk4.
tentioner failed. lucky the cambelt didnt nock the timing out.
made a tappety noise.
 :shocked:
