Author Topic: what underseal  (Read 3143 times)
turbo
what underseal
« on: 31 December 2003, 00:07 »
just wondering what underseal you guy use..... ???
i use waxoyl on brake lines just wondering what ppl use on the underside as ive used the hammerite black stuff before its good stuff but it attracts the mot inspectors screw driver!!!!
would hammerite paint be as useful.... or can i get hold of the thick vw underseal...... ???
ideas please
Offline Dragon6
Re:what underseal
« Reply #1 on: 31 December 2003, 12:25 »
I use a couple of coats of black hammerite paint over all the underside,cover brake lines in waxoil,spray waxoil inside the box sections and all over rear beam around fuel pump behind rear valance etc,then this time of year brush on a light coating of waxoil onto the floor pan sill edges etc,found this method works well,it is easily removed with white spirits or petrol if need to do any work.Just give it all a good wire brush first,done this method on both my mk2`s and had no probs..dont like usual underseal stuff myself due to being thick and permanantly tacky,I did enquire about the original type of underseal at my local bodyshop but they said it was very expensive and due to the cost only usually used on insurance jobs around ?20 for a silicone sized tube..
« Last Edit: 31 December 2003, 12:32 by oakie.uk »
Blue MK2
Re:what underseal
« Reply #2 on: 31 December 2003, 13:19 »
love the car oakie ;)
Does underseal come in spray cans?
Offline Dragon6
Re:what underseal
« Reply #3 on: 31 December 2003, 13:50 »
thanks Blue2  :)yep it comes in all types applications,I find the best approach is to use  waxoil in the pump action kits you can buy from motor shops they cost around ?25 but the can needs a good heating to melt the stuff first,or it wont spray,I have used the black underseal b4 but I found that if the surface wasnt 100% rust free then it could still rust away underneath  but that was on a ford though :'( but if you are as sad as me and powerwash sponge the underside of the car ever so oft in this weather all the underside is a nice glossy finish when you use black hammerite paint so is as easy as cleaning your car bodywork,just a good wirebrush and slap it on stays as good as new bit of a crappy job but its worth it in the long run :)
turbo
Re:what underseal
« Reply #4 on: 31 December 2003, 13:52 »
cheers i guess its hammerite then......
Blue MK2
Re:what underseal
« Reply #5 on: 31 December 2003, 17:06 »
yes im sad too.  ;D
Offline Dragon6
Re:what underseal
« Reply #6 on: 31 December 2003, 18:55 »
cheers thats 2 of us then I even take off all the body kit/bumpers and waxoil behind all that b4 all the crappy weather as well, :)
Offline Gt-tdi
Re:what underseal
« Reply #7 on: 03 January 2004, 20:41 »
can i jus say oakie has a LOVELY lookin car! well done.
TDI = economy and FAST!!
Offline Dragon6
Re:what underseal
« Reply #8 on: 04 January 2004, 12:17 »
Thanks for your comment G-tdi  it makes changing gearboxes in the dark with a lead lamp and the afore metioned hammeritein and all the other crappy jobs all worth while... :) :)
