Author Topic: i need to get good fuel consumption from my 1.8t golf  (Read 2774 times)
Offline warwickcool
  • drop it like its hot!!
now then ladz,just need some advice regarding changing my ecu on my 1.8T golf,its 1999 and has been remapped to aprox 197bhp,this is all well and good if you want to bring a smile to your face but not when your pulling in the garage every day,i know i should realy fill it up but if i did this it would definately cause me to drive faster,can i replace my ecu with a standard 150bhp ecu or is there more too it than that,also the mpg readout on the trip computer has a mind of its own as does the fuel gauge,the fuel gauge only reads correct on a flat straight road,if theres a bend it seams like the fuel gauge moves with the fuel if ya get what i mean,please help me before i have to start thinking about tdi's,thanks
Offline HARDCOR3
Re: i need to get good fuel consumption from my 1.8t golf
« Reply #1 on: 29 August 2006, 22:12 »
burn it for the insurance......
should've bought an economical VR like i told ya :huh:, would've had a quick car then too :wink:....
Offline warwickcool
« Reply #2 on: 29 August 2006, 22:17 »
just want a standard ecu and save the other one for fun times  :grin:
Offline Rhyso
« Reply #3 on: 30 August 2006, 08:21 »
did u have it Revo'd?
IIRC you can buy a switching box which reverts the ECU back to standard when you want to. or go back to the people who remapped you r car and ask what options are available.
If that fails buy a TDI  :wink:
Offline topher
  • Administrator
  • fully functioning
« Reply #4 on: 30 August 2006, 12:04 »
take it to vw and get the stock map flashed back to it. i dont see the problem though.. mine is putting out more than yours and i get a decent mpg if i drive steady. could there be another problem ?
p.s vr's are old and slow.
Offline charri42
« Reply #5 on: 30 August 2006, 13:06 »
I would do an MPG test to see if it really is that bad.
Brim it, run till nearly empty and fill it - work out what you're really getting.
If its in the 30's then changing to a standard map won't make a massive impact (depending on the kind of driving you do, I always averaged low/mid 30's in my 3 1.8t cars)
Offline HARDCOR3
« Reply #6 on: 30 August 2006, 20:03 »
And you can allways weigh a Mk4 in for more money, eh toph.... :grin: :grin:
:afro:
Offline warwickcool
« Reply #7 on: 30 August 2006, 20:14 »
whats yours pushin toph,i got 70 miles to a tenner the other day,gave it a lil bit here and there,is that any good,its a powerplus engineering remap if that helps :grin:
Offline warwickcool
« Reply #8 on: 30 August 2006, 20:16 »
rhyso, where  would i find such an item as the iirc, :smiley:
Offline Rhyso
« Reply #9 on: 30 August 2006, 20:20 »
IIRC = if i remember correctly
couldn't  be bothered to type it all out in my previous post  :grin:
