Author Topic: bilistic idle on 8v gti  (Read 1945 times)
turbo
« on: 29 December 2003, 19:35 »
my idle wont set ive cleaned the isv its buzzing and also disconected the temp sender while doing it but when i replace the sender wire it revs high...... ???
not long ago i brought some injection cleaner same stuff as 10k boost you spray in to the throttle... so i took the pvc off and sprayed through that so it would clean the throttle and it worked! idle  was perfect and a few weeks later back to stage 1.....
i have had a new temp sender and that makes no difference.........
would the dealer fix this problem........
any ideas on whats wrong.......... :(
golfvr6
Re:bilistic idle on 8v gti
« Reply #1 on: 30 December 2003, 09:00 »
Problem with the temp sensor circuit? sounds strange that it does it only when its plugged in. Test the wiring.
turbo
« Reply #2 on: 30 December 2003, 20:13 »
when its running and i disconect the isv it stalls.
i'm going to have another go at setting it again....
if i cant do it i'll book it in at the dealers.
at least if they tell me what needs replacing i can replace it.... :(
