Author Topic: final touch help  (Read 1048 times)
Offline VR6_ROB
  • Mk2 VR6 / Corrado G60
final touch help
« on: 23 August 2006, 20:56 »
hey all
got few little daft problems with my mk2 vr6
wonder if anyone can help
my rear light on the passenger side keeps blowing its fuse for fun
wiring seems fine when i checked it out
and the vr6 clocks they is 3 plugs on the loom
2 blue plugs which go where gti loom went
and a small black plug i dont know where this goes
and i think its causing them not to work properly
oh and is they any decent places for alloys
i am after some tt ones in black spoked forgot name of them
cheers
rob
Offline blgdave
Re: final touch help
« Reply #1 on: 27 August 2006, 10:03 »
For your wheels, just give good old Google a shout. I just did a quick search now and this one came up as a starter for ten...
http://www.alloy-wheels-shop.co.uk/
On your lights I would sugest that a live is being earthed some place through a worn insulation sleeve. It may be a wire some place with a nick or scrape in the insulation that only makes contact with earth when driving or bumping about. When you run a tester through it that earth may not be ebing made so will appear ok. Just a suggestion as it could be many things from teh switch to the bulb holders? Also sounds daft, but the bulb may be the wrong type?
CheeRS
Dave...
