Author Topic: Guidance for tomorrow (30th) please  (Read 3289 times)
Offline daros
« on: 29 December 2003, 17:58 »
I have my '91 GTi 8v in for its first service tomorrow since I bought it and hope you can provide me with the following info. My rev counter, MFA and water temp guage dont function the majority of the time (having come to life briefly twice during the last week!). Clearly there is just something loose somewhere (rather than them being fcuk'd  ;) ) so I am hoping to advise the garage of where to check!.
Advice gratefully received as always
David
Offline mk1
Re:Guidance for tomorrow (30th) please
« Reply #1 on: 29 December 2003, 18:55 »
Check the earth wire on the rear of the rocker cover.
Steve.
Offline daros
« Reply #2 on: 01 January 2004, 13:52 »
Steve.
Checked and no joy :(........this is v frustrating now as the thing clearly works apart from something loose somwhere!! grrr lol
Offline Helios_Blue_Valver
« Reply #3 on: 01 January 2004, 14:18 »
Sounds like an earthing problem to me. Should be a brown wire off ot the back of the clocks that goes to the ground stud on the back of the block. Check behind the clocks and see if this wire has come loose or maybe is corroded. Also check the vacumm line at the back of the clock and see if it is split or leaking. could be the MFA problem. :)
Brad
Offline daros
« Reply #4 on: 01 January 2004, 17:09 »
Brad
Does the whole dash need to come off to get access to this?
David
« Reply #5 on: 01 January 2004, 19:30 »
May be able to get a look by pulling out your head unit.
Offline daros
« Reply #6 on: 01 January 2004, 20:52 »
Head Unit??........sorry, new to all this!
« Reply #7 on: 02 January 2004, 16:15 »
Head Unit = Stereo :)
Have you tried removing the fuse for a day or so, this resets the unit possibly will solve your problem?
I also have a spare set of clocks in the for sale section, 120mph 7k rpm let me know if you're interested ;)
« Last Edit: 02 January 2004, 16:17 by rubjonny »
Blue MK2
« Reply #8 on: 02 January 2004, 16:52 »
whats the milage on them rubber jonny?
Offline daros
« Reply #9 on: 02 January 2004, 18:08 »
Thanks for the offer however as they are still functional I shall perservere with the find the loose wire lark!!
