Author Topic: Hall sensor?????????  (Read 1508 times)
Offline SAD VR6
« on: 23 August 2006, 07:29 »
What is it ?
Where is it ?
 :cry: :cry:
THE FIRST GUY TO MILK A COW, WHAT THE F*$K WAS HE DOING??????
Offline V_Arse6
Re: Hall sensor?????????
« Reply #1 on: 23 August 2006, 13:59 »
What is it ?
Where is it ?
 :cry: :cry:
Unless I'm having a brain fart, that's the cam position sensor, yes?
If so it's at the right-hand side of the engine (looking from the front), under all the bits of trim.  You've got to remove the coil pack to get it off, so pay attention to where all the leads go, and be careful with all that stuff - break something and your car may well not run/start.
Plus disconnect battery of course, as always when working with the ignition system (lots of Volts = Lots of pain :evil:)
I've removed and cleaned mine, just to be sure (it didn't really need it though).  I might have some instructions at home somewhere :undecided:
'95 Mk3 VR6
FK Highsports, Crystal Clear Fogs/Indicators/Repeaters, Mk4 Style Headlights, PiperX induction, Bonnet lifters. (Need to update pic for new headlights)
« Reply #2 on: 23 August 2006, 14:48 »
hall sensor is in the dizzy, its what that 3 pin plug that connects to the side of it is for :)
Offline SAD VR6
« Reply #3 on: 23 August 2006, 22:21 »
Cheers chaps il look tomorrow
Offline V_Arse6
« Reply #4 on: 25 August 2006, 11:01 »
I assumed from his username he's got a VR6 lump...  :wink:
'95 Mk3 VR6
Offline SAD VR6
« Reply #5 on: 25 August 2006, 23:04 »
Oh yes.  :grin:
« Reply #6 on: 26 August 2006, 09:46 »
well either way, the hall sender is in the dizzy if one is fitted ;)
Offline spankyVR6
  • better a seated piss than a standing sh!te
« Reply #7 on: 01 September 2006, 13:40 »
I cleaned the hall sender on mine a bit a go. It was behind the coil pack going into the head (coil pack off job, but i left all the ht leads attached to it and moved it out of the way). nice and easy to take out and clean. as ChipDeath said mine didn't really need it either, but when i put mine back together it was stalling all the time so I cleaned out the throttlebody (when reattaching the battery i left the ignition on and left everything for 30mins to reset) and all is fine now!
Hope this helps :wink:
