Author Topic: Fitting side tension cables  (Read 3503 times)
Offline rzacasperof
« on: 21 August 2006, 23:13 »
Any one had any experience doing this?  Roof on my CAB bows up in the middle so I guess the tension cables need replacing.  Do you need to remove the roof to replace them?  Is it a difficult job?
Offline gibby
Re: Fitting side tension cables
« Reply #1 on: 22 August 2006, 13:38 »
When I had my roof fitted last year the side bits were flapping about so I took it back to the guy who fit it and he tightened the tension cables at the C pillar side. I think he took the roof down about half way and then unstuck the roof from the roof frame to get into the cables, he then tightened them up and stuck it back down. Did the trick anyway. As for difficulty ? He knew what he was doing and it was easy, I wouldn't have known what to do.
......now officially dubless.
Offline rzacasperof
« Reply #2 on: 22 August 2006, 14:21 »
Thanks mate.  Gonna get the cables hopefuly next week and thenk have a crack at it.  Fingers crossed it won't be to difficult :)
Offline gibby
« Reply #3 on: 22 August 2006, 15:08 »
oops, I appear to have answered your question wrong as I answered "How do you tighten up the tension cables" !  :embarassed:  :laugh:
« Reply #4 on: 23 August 2006, 14:56 »
they hook up on the rear down by the C pillar, if you put the roof half up you can see the cables running along the hood frame.  Check both sides see if either have snapped, common fault for ones that are getting on a bit!
Offline rzacasperof
« Reply #5 on: 24 August 2006, 13:05 »
so it's possible to replace them without removing the roof?
« Reply #6 on: 24 August 2006, 13:12 »
yes :)
I think you just have to take the rubber seals off the C pillars and above the front doors to get to em.  We certanly didn't have the roof off when we replaced them on our cabby!
Offline rzacasperof
« Reply #7 on: 25 August 2006, 11:37 »
Cool, thanks mate :)
Will attempt it soon then and if all goes well take some pics and do a 'how to' as i've not seen one anywhere.
Thanks again for the help :)
« Reply #8 on: 25 August 2006, 11:42 »
no problem, giz a shout if you get stuck, I have the hood fitting instructions in the garage somewhere  :grin:
Offline blgdave
« Reply #9 on: 27 August 2006, 10:08 »
Going to do a roof swap myself in a few weeks. Dont suppose you have a copy of them instructions scanned do you mate?
Also how much do these cables cost and is it a dealer part only? Could they not be made up from any wire cable?
CheeRS
Dave...
