Author Topic: Vacuum Leak - Why no Jubilee Clips ?  (Read 1358 times)
Offline Xiotis
« on: 20 August 2006, 16:41 »
I am trying to find the cause of a rough lumpy idle on my GTI 16V and I removed the ISV and no change.
What I did notice though was that the pipes from the air intake boot to the ISV are fitted fairly loosely among each other (rubber to platic pipe) and don't have any jubilee clips on them. Would they have originally had clips on them?
CheerZ!
Mk2 Golf GTI 16V
Veedubgt18v
Re: Vacuum Leak - Why no Jubilee Clips ?
« Reply #1 on: 20 August 2006, 16:55 »
yes they would
Offline Xiotis
« Reply #2 on: 21 August 2006, 07:23 »
Thanks Veedub.
I have seen so many without that I was thinking it was the norm!
Just to clarify what I mean, here is a random pic I found on the net which is like mine and is missing the clips (marked with yellow arrows).
Mk2 Golf GTI 16V
VeeDubGTI16v
« Reply #3 on: 21 August 2006, 11:49 »
Mine doesnt have them there either
What sort of rad is in that valver? its huge!
Offline Xiotis
« Reply #4 on: 21 August 2006, 12:03 »
I have seen some with and some without, as a precaution i will put come clips on mine.
That valver is a transplant from a (US or Canadian not sure) Spec 2.0 16V Passat.
Here is where I found the pic from http://forums.vwvortex.com/zerothread?id=1763775
« Last Edit: 21 August 2006, 12:04 by Xiotis »
Mk2 Golf GTI 16V
Offline Gambit
« Reply #5 on: 22 August 2006, 13:30 »
you wont need the clips on there.
did you check your injector seals?
Offline Xiotis
« Reply #6 on: 22 August 2006, 15:53 »
Hi Gambit,
No I didnt think to check them  :rolleyes:.  I will spray some WD40 on them and see if there is a change in idle.
Thanks for the tip.
Mk2 Golf GTI 16V
Judderi
« Reply #7 on: 23 August 2006, 13:12 »
I put clips on all mine as any leak will screw up the metering.
