Author Topic: head seals  (Read 748 times)
Offline rowlers
  • I'm back - MK7 GTI
head seals
« on: 19 August 2006, 08:40 »
I As part of the head gasket set i've got, I have 2 rubber o-rings and another rubber rings wuth an odd shape anyone tell me what they are for and where they go?
I'm thinking they are seals for the distrubutor? the other one matches a shape on the front of the head, below the where inlet  manifold bolts on.
I'll get pics if it helps!
ta
See some of you 2moro???
Re: head seals
« Reply #1 on: 21 August 2006, 13:03 »
one will probably be a camshaft seal, other is probably the coolant channel o'ring seal which is only present on carby heads :)
