Author Topic: Water leak  (Read 878 times)
Offline dazzer19666
Water leak
« on: 18 August 2006, 21:03 »
Hi can any one help. My MK 3 has got a leak there is a lot of water in the rear passenger footwell and teh boot is soaked on the same side.
Has anybody had the same problem,if so acn you please advise.
Many thanks.
Offline harlemex
Re: Water leak
« Reply #1 on: 05 March 2008, 22:31 »
Hi, had the same prob. rear light seals leaking. The water runs in across the boot and down undenearh the rear seat into the footwell. You could buy new seals or try silicone sealant, has worked for me so far.
Offline saul79
Re: Water leak
« Reply #2 on: 05 March 2008, 22:32 »
asa above and if you have a 4 door check the door seals on all the doors (behind the doorcard)
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
