Author Topic: Wiring to sidelight feed?  (Read 1290 times)
Offline gtitdi
« on: 16 August 2006, 22:43 »
Is it possible to wire up some interior lights or LEDs so that they come on when the sidelights are turned on? If so where can I connect to?
Re: Wiring to sidelight feed?
« Reply #1 on: 17 August 2006, 17:23 »
Look for the blue/grey wire, this is the lights on feed.
I found a handy spare plug with a grey/blue wire hanging out the back of my fusebox, mines a CE2 MK2 so pretty much the same as a MK3 :)
Offline gtitdi
« Reply #2 on: 18 August 2006, 16:35 »
Thanks, I'll have a look!
Offline gtitdi
« Reply #3 on: 18 August 2006, 18:16 »
I found the same wire coming from the back of the headlight switch, can I take a feed from this?
« Reply #4 on: 18 August 2006, 18:19 »
You can indeed, its just neater to run a spade to that spare connector as it saves you having to splice into any existing wires.  Its up to you though :)
Offline gtitdi
« Reply #5 on: 18 August 2006, 20:48 »
I couldn't see the spare wire in the fusebox, is it just a wire with nothing on the end?
« Reply #6 on: 19 August 2006, 08:02 »
yup, its just a blue/grey wire with an ampty plug on it.  It may not be there on a MK3, I just assumed it was since the late MK2 fusebox is the same.
