Author Topic: iam havin a bad day!...  (Read 1032 times)
Offline SI_GTI
« on: 14 August 2006, 21:26 »
just got outta work and my drivers side window will not go up its leccy,but then soon after i heard a ticking noise coming from the gearbox only when moving jumped out to have a look and there was a puddle of oil sitting under the gearbox!! :cry:so i dont know were to start??,the plate that covers the box has a nut missing from it though??i dont wat to do anyone got any ideas on wat to do next??all help appreciated
Re: iam havin a bad day!...
« Reply #1 on: 15 August 2006, 12:21 »
1st thing is get it up in the air and have a good look at the box, you're looking for any dirty great holes in the housing!
Offline SI_GTI
« Reply #2 on: 16 August 2006, 08:39 »
the diff pin has blown off into the gearbox,so iam gonna try and ally wled the box then weld the pin bak to the diff. :smiley:
« Reply #3 on: 16 August 2006, 08:48 »
good luck with that!  I think its going to have serious internal damage you should realy be looking for another box I'm afraid :(
Judderi
« Reply #4 on: 16 August 2006, 09:54 »
Its a common problem, best bet is to get a new box and get the diff bolted on.
Offline SI_GTI
« Reply #5 on: 16 August 2006, 12:57 »
probably will end up doin that its just finding a decent one though thats the prob :laugh:
Offline Gambit
« Reply #6 on: 16 August 2006, 12:59 »
safer bet would be to take it to a gearbox specialist and let them advise on whats the best way forward.
some boxes are repairable. mine was but it didnt split the casing when the diff went
2nd hand box can be hit miss. although 8v boxes dont suffer the same failure rates as the 16v boxes
Offline SI_GTI
« Reply #7 on: 16 August 2006, 13:01 »
will do that iam no rush anyways
