Author Topic: What filter  (Read 1246 times)
Offline Bigdunc
What filter
« on: 14 August 2006, 21:24 »
hi im wondering what filter to use i have i got a mk2 golf driver 1.6 i was wondering should i stick to the air box with my k+N pannel filter or shall i swap to a K+N bolt on to go direct on to the carb.
is there much of a differance.
Offline Agreeable Slick
  • Unit
Re: What filter
« Reply #1 on: 14 August 2006, 21:32 »
panel
Offline barkstar
Re: What filter
« Reply #2 on: 14 August 2006, 21:47 »
I just run a std filter - they're £4 a pop, that's a lot of filters at one a year compared with £30+ for KN, and no discernable extra go. If you do get a KN get a panel one, the Drivers do suffer from car icing if the hot air supply system isn't working, not a problem this time of years but a serious pain come winter.
barkstar  :nerd:
Offline Bigdunc
Re: What filter
« Reply #3 on: 14 August 2006, 21:56 »
so ill stick with the pannel filter then. what i am after though is the foam thingy that goes on the end of the air box. or could i get some tubeing and shove it out the front of the car to increase air flow.
Offline Bigdunc
What gears
« Reply #4 on: 14 August 2006, 22:28 »
Thought id ask just been reading on the net some guys saying they got like up to 60mph in 2nd gear i was wondering isnt that bad for the car. i have no rev counter and im not sure how far to push my gears could anyone suggest what speeds to do in what gears. i got a 1.6 driver.
  • Unit
Re: What filter
« Reply #5 on: 14 August 2006, 22:30 »
I can easily get that in second, but then i would presume that like mine they are not standard engines.
Offline [han]
  • Graphic Designer for Haribo
Re: What filter
« Reply #6 on: 15 August 2006, 08:03 »
£4 a go? where are u gettin urs from? i pay 2.50 inc vat  :laugh:
i'd go panel everytime! i've been quite tempted to put a k&n or green cotton or similar brand panel filter in - they have a million mile warranty, and just need cleanin every now n again!
maybe thats an option? peoples opinions are appreciated!!
Re: What gears
« Reply #7 on: 15 August 2006, 12:24 »
That foam pipe isn't really necessary, just bin it.  If you like you can run a cold air feed to the grill, but don't expect any major difference  :grin:
Save that £30 from a K&N, and buy yourself a set of GTI dash clocks, just plug in and the rev counter will work :cool:
Check the hazard switch 1st, if its on the dash you need 2 plug clocks, if its on the column you need single plug clocks.
If you feel adventurous you can get the MFA working, but if not it will just function as a digital clock :)
