Author Topic: glovebox removal driving me mad  (Read 2526 times)
Offline Diluxe
« on: 27 December 2003, 14:13 »
Hi Guys,
been trying to get the glove box out for about 30 mins now, taken 7 screws out in total but the buggers just not moving, is there some hidden ones or something?
cheers ::)
1997 16V
Veedubgt18v
Re:glovebox removal driving me mad
« Reply #1 on: 27 December 2003, 18:08 »
Glove box light? or does it come out from behind not thru the aperture if you know what i mean!
Offline Dragon6
« Reply #2 on: 27 December 2003, 18:13 »
yes its a pain in the ar$e that one took mine out earlier in the year to fit my changer,if I remeber right the glovebox wedges itsselff on the air vent ducts as u try to withdraw it, take out the two bolts either side of the dash and think theres a couple behind the glovebox area in the engine  compartment on the bulkhead this then gives u enough movement to pull the dash forward then pull the glovebox out..or something like that :)
Offline workhorse '90 8v
« Reply #3 on: 27 December 2003, 18:27 »
Haynes manuals - worth their weight in err lead - but they're usually pretty good at explaining how to take bits apart..
Offline Dizzie
  • Make friends with your fast
« Reply #4 on: 27 December 2003, 18:50 »
it doesn't tell you in the haynes though afaik
there's a lump on the top of the glovebox that stops it coming out unless you have enough of an angle. to get that angle you have to remove heating vents I think. When I was removing the whole dash the glove box wasn't free until the dash was actually in my garage!
the mk3 one is so much easier it's unbelievable.
R1D3R
« Reply #5 on: 27 December 2003, 23:08 »
mk3 dash blah blah blah  ::)
always 1 step ahead.......
Offline jedi16v
« Reply #6 on: 28 December 2003, 00:28 »
i think haynes manuals are complete cr$$
Offline VW2010
« Reply #7 on: 28 December 2003, 14:10 »
I couldn't agree more, completely useless, not in-depth enough..........
Offline Helios_Blue_Valver
« Reply #8 on: 28 December 2003, 17:06 »
I love it when it gives you all the no brainer stuff than tells you to contact the main garage if it doesn't work. lol. If I wanted to take it to VW I wouldn't own a Haynes manual. Bently by far better.
