Author Topic: Stupid G60 Suspension questions!  (Read 971 times)
Offline 16v Matt
« on: 14 August 2006, 09:42 »
Hi everyone,
Mate of mine has an edition one G60.   I'm going to be fitting some coilovers for him.  I fitted coilovers to my 16v, a corrado, polo gti & a G40. So I can't see it being much of a problem, my question is does the G60 suspension differ much to a 16v or a rado?
Also he wants it polybushing which is somthing I've never done before, can't imagine its that difficult?  Any specific tools required to do it?
Or, would it be better just to stick some new vw bushes on as he wants to retain some sort of ride quailty & its never going to see a track day.
Or poly jobbies on the front & OE ones on the back or visa versa?
Sorry for the daft questions :embarassed:  any tips on replacing bushes would be very handy.
Cheers in advance :kiss:
Re: Stupid G60 Suspension questions!
« Reply #1 on: 14 August 2006, 10:49 »
Only difference is G60s have tougher front top mounts, but they're physically the same shape as normal MK2 ones, its generally a good idea to buy G60 top mounts when doing the suspention on a 'normal' MK2 anyway :)
One thing to note though, if it has the Synchro setup the rear shocks are different to normal MK2 ones!
Poly bushes are dead easy, a few hours per side along with some harsh language :grin:
It might be an idea to get a set of spare wishbones so you can just swap em over, but I didn't bother in the end!
I'd go for Poly all round as fitting is much easier, for OE you really need to get them fitted by a garage, especially the rear beam ones!
Wishbone bushes:
Getting the old ones out is the hard part!  For the large rear ones, cut/drill/burn out the rubber center, chop a groove in the outer metal ring, then use a hammer & chisel  or metal drift to bash it out.  The front ones are a bit more tricky, I chopped the rubber lip off then used my pullers to push them out.  A bench vice would make the job easier though, or a g-clamp could do it.  You just need something small enough to fit in the hole which will locate against the metal slieve.
To get the new bushes in, chuck em in a bowl of hot water for a bit to soften, then smear a ton of copper grease into the holes and on the bushes (to stop em squeeking!).  For the large round one, I found the easiest way was to put the bush on the ground, then sit the wishbone on top, and stamp on it!  For the smaller bush they are supplied in 2 halves so just slip in easy.
1 tip for you though, before you do anything else check the metal slieves fit inside the mounting holes, I found my rallydesign front slieves wouldnt fit in the mounting hole on the subframe, so I had to grind them down with my dremel!
ARB drop links are dead easy, simply chop a slit along the rubber and they push out, then to refit I put the link on the ground, sit the bush on top and press down on it with my foot while I lever the lip in using a large screwdriver.  Once its started just stamp on it to get them all the way in!
The rear beam is the most tricky to do, you can do it without taking the beam off completly though.  Jack up the rear & support on axle stands, then use a trolley chack to support the beam.  Undo the pivot bolt on one side, and use the jack to lower it slowly onto something which is large enough to support it at the right height.  Then as per wishbone bushes, drill out the rubber part and then cut a slit in the metal slieve & bash it out with a hammer :)
Poly bushes then simply slide in place.
Problem with the beam though is the rear brake bias valve gets in the way of one of the pivot bolts I think?
« Last Edit: 14 August 2006, 10:51 by rubjonny »
Offline Organisys
  • Old and Slow...
« Reply #2 on: 14 August 2006, 12:51 »
Just to re-inforce what RubJ has said above.
1) G60 the same
2) Get G60 top mounts at the same time, less likely to give out
3) If it were me, I'd OEM bush it.
4) Buy new wishbones and ball joints, not much more money, and well worthwhile doing
5) Get rear beam bushes done in a garage.
If he must have polys, only do the front to sharpen steering up, rear use OEM to retain the designed in passive rear steer.
Offline 16v Matt
« Reply #3 on: 14 August 2006, 13:13 »
Thats spot on :smiley:, thanks very much guys.
Knew you would'nt let me down :wink: :smiley:
Thanks again. :smiley:
