Author Topic: Help.... speedo cable  (Read 8582 times)
Offline Dub-77
  • Dub again MK1 Golf Project
« on: 13 August 2006, 14:19 »
Can anyone tell me if this looks normal or is there something missing from the end of the speedo cable.
Picture wont display :angry: :angry:
Try this link please http://www.photobox.co.uk/album/3720101
« Last Edit: 13 August 2006, 14:38 by Dub-77 »
Show me a man with a tattoo and i'll show you a man with an interesting past :wink:
Offline Agreeable Slick
  • Unit
Re: Help.... speedo cable
« Reply #1 on: 13 August 2006, 14:22 »
Wouldn't be able to say cos i can't see sh!t.
Offline Dub-77
« Reply #2 on: 13 August 2006, 14:40 »
  • Unit
« Reply #3 on: 13 August 2006, 14:48 »
Yep there is a gear that is meant to go on the end, it should have been attatched when you pulled it out of the gearbox.
Offline Dub-77
« Reply #4 on: 13 August 2006, 14:49 »
Oh thats not good then is it? :cry:
What would you suggest i do now please Slick????
  • Unit
« Reply #5 on: 13 August 2006, 14:59 »
well presuming it has fallen off in the gearbox then it needs to be retrived, the gear peices themselves can be bought from VW i am pretty sure, however you will need to know which colour it is that you will need, i believe there are green, white, and red. Mine was a red on (89 valver)
Retrieving it i have heard people just run it for a while, then drain the box, and all the reminance of the old gear come out with that. Not the best idea i reckon personally, but i have heard it works.
Offline Dub-77
« Reply #6 on: 13 August 2006, 15:12 »
I've just sucked out some of the oil via the speedo hole say about 200ml and i did not see anything in there had a route around did not feel any thing either.
The reason i was in there was the speedo was not working so it may well have dissappeared a while ago?
So now the job of finding out what colour it was?
If i buy a new speedo cable will this gear not come with it?
Thanks for all your help on this.
  • Unit
« Reply #7 on: 13 August 2006, 15:23 »
Unfortunately not, the cable is just the part to connect into the back of the clocks and mount onto the gearbox. If it has fallen off a while ago then drain the box and you should see the parts of it coming out in the oil.
Offline Dub-77
« Reply #8 on: 13 August 2006, 15:53 »
gearbox drained no signs of it at all :huh:
Maybe the guy who had it before me had some work done on the box and it was lost then?
I just gotta find out what colour gear i need now.
If any one can help the golf is a 1990 1.8 16v
Darren
Offline takethefifth
« Reply #9 on: 13 August 2006, 16:33 »
Whats the max speed shown on your clocks?  The 120 and 160 mph clocks use the same colour gear (white?) and the 140mph ones a different one (red?) .
Can't remember for sure which colours are which but if you do a search the details are here somewhere!  :smiley:
