Author Topic: Clutch bite..really high up pedal!!  (Read 1048 times)
Offline boneybradley
  • Back in a Mk3...
« on: 12 August 2006, 18:48 »
Hi, I have got a problem with my clutch, It bite's nearly at the top of the pedal, I have changed the cable hoping this would sort it but it's still high. I did on my last golf have the broken ratchet problem on the clutch arm and when i broke the car up I kept the new ratchet and clutch arm ( which I will fit at some point). But when driving it feel's very different to when that started to go..any advice please!!        p.s i didn't mention but my box is a bit notchy when going into first, don't know if this is relevant but i thought i would add this :undecided:
Offline carl
Re: Clutch bite..really high up pedal!!
« Reply #1 on: 12 August 2006, 21:27 »
hi
first of all did you replace the cable with a new one,
if so i would say you need a new clutch sometime soon.
Offline AudiA8Quattro
« Reply #2 on: 13 August 2006, 00:11 »
Probably a new clutch then if the cable is ok.
