Golf mk2
ecu overfuelling
Topic: ecu overfuelling (Read 859 times)
davc
Just got here
ecu overfuelling
12 August 2006, 16:32 »
hiya just done head gasket ,now ive got an overfueling problem
when i turn on ignition the pump and injectors stay on ,,checked earths ,,relays ,,must be the ecu hope it aint ,,ive got a 1.8 digifant
dubslug
Re: ecu overfuelling
12 August 2006, 17:19 »
if i cont. buzzes mine did that and turned out to be a blown ecu
1992 pearl grey 8v
AudiA8Quattro
Forum addict
13 August 2006, 00:05 »
Is the engine earth strap connected? if you missed it after reassembling your engine then i'm afraid your ECU is probably fried...
mexicorich
13 August 2006, 00:17 »
Welcome to the wonderful world of Digifant
stan_deezy
GTI forum regular
13 August 2006, 14:27 »
You checked the fuel pump relay didn't you? Might have failed "energised" and hence isn't shutting down.
Sounds like the earth strap either between the gearbox and battery or the one between the coil and rocker cover but...........did you try turning the engine over without having the plugs in or the HT leads off? This too can cause a huge voltage spike through the ecu (and the hall sender in the dizzy).
Also, just to cheer you up (not) check your oil level now. You may well find, as I did, that the sump has filled with fuel. You're looking at an oil and filter change probably twice just to get rid of the petrol.
Golf mk2
ecu overfuelling
