Author Topic: Wet feet!!  (Read 2017 times)
Offline wayders
  • Built by the germans, thrashed by the british!
Wet feet!!
« on: 11 August 2006, 16:26 »
Can anyone help me out? Since the rain has started again iv noticed a small leak that drips on my feet, it seems to be coming from above the pedals, does anyone know where this leak is coming from and how do i fix it? Many thanks..
Offline Uruk Hai
Re: Wet feet!!
« Reply #1 on: 11 August 2006, 17:30 »
Could be one of the grommets in the bulk head has had it or your windscreen could be leaking
Offline Dave_P
Re: Wet feet!!
« Reply #2 on: 11 August 2006, 18:33 »
yes i agree, 1 of your drainage gromets has probably come loose or damaged, its in the compartment where your front window wiper is, i had a cable touching it once and the water was draining onto the cable and running down it and into the car where it entered, once it gets there it touches the carpet and soaks into it at that point. hope this helps, Dave P ...
Offline gibby
Re: Wet feet!!
« Reply #3 on: 13 August 2006, 09:30 »
Yup, first thing to try are the drainage holes in the bulk head, there should be two at each wing side and they usually get full of leaves and cr@p so then water builds up in there.
......now officially dubless.
Offline wayders
Re: Wet feet!!
« Reply #4 on: 13 August 2006, 10:28 »
Many thanks peeps, i'll check it out later..
Offline GemGTI
  • Gemma
Re: Wet feet!!
« Reply #5 on: 13 August 2006, 16:40 »
I have had this problem for over a year now and I think its finally sorted. For ages I couldn't work out where it was coming in, then I noticed water dripping on my feet as I was driving up a hill, since having engine re build (when they also filled craks and holes in bulkhead and pained engine bay) It (so far) hasn't leaked. So I'd say check this out too.
G
Offline wayders
Re: Wet feet!!
« Reply #6 on: 13 August 2006, 17:46 »
Iv recently had my bulkhead plate replaced from where my clutch came thro and it seems to have come loose again, i think my leak could be coming in from that hole! many thanks anyway mate..
